iat and iacv code problems need help
my eg hatch with b20 vtec swap is throwing the iacv and iat code. the sensors checked out according the the manual and the voltage from the ecu as well. I replace the sensors anyway. still throwing codes. Everyone has told me that i have the plugs mixed up, and i need to switch them. thats not the problem either. could it be a setting in the s300? the car has not been tuned. i dont want to take it to the dyno throwing codes. any suggestions would be appreciated.
Re: iat and iacv code problems need help
are you sure they are not hooked up backwards? I have seen this many times they are the same plug.. look at the wires there should be a green/white and red wire at the iat i belive.. its deff not a setting in the s300, switch the plugs and see what happens
I have reset the ecu and checked the voltage coming to the plug but not the ground. Ill check that when I get home. im using a civic cx wiring harness that has alot of plug not in use mainly around the dizzy. could that be an issue? The shell has also been converted from auto to manual.
