idle problems
Old 11-02-2010, 11:38 AM
Oh hey
TiredToyotaDrvr's Avatar
TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr TiredToyotaDrvr
Default Re: idle problems
Originally Posted by Integra2Be
thank you, ill try that. But i doubt there are any leaks.
however, i did delete the charcoal canister and now there is an open port on the TB.
This would make a vacuum leak... You mean where the EVAP purge valve used to sit there is a hole? Definitely plug this up... use rubber plugs or metal freeze plugs w some goop on them...
Edit: Which ECU??
TiredToyotaDrvr is offline
Old 11-02-2010, 05:26 PM
Hi
Integra2Be's Avatar
Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be
Originally Posted by NasTHatch
i thought your clutch was done?
It is, but id like to get the engine running right and im thinking about just fixing it. Havent made up my mind yet.
Originally Posted by blackngoldIS
what ECU are you running?
Stock Ls Ecu PR4, i think.
Edit: Which ECU??
yes and and where the canister direcly plugged into the TB.
Integra2Be is offline
jus10
03-07-2006 01:24 PM
Blaznkwest
12-30-2005 07:24 PM
ECR
11-27-2005 11:20 AM
sir92hatch
11-02-2005 05:11 AM
CJ0920
08-19-2005 06:39 AM
Quick Reply: idle problems
