idling too high, please help
Old 08-24-2006, 08:45 PM
  #21
KhanArtisT's Avatar
KhanArtisT has disabled reputation
Default Re: idling too high, please help
Originally Posted by snozepp147
i would i do an intake pressure test? i hear a hissing sound coming from near the firewall, it sounds like its coming from the EVAP canister, but i tightened all the hoses going into that and that wasn't it. how can i find out where this leak is coming from?
buy carb cleaner/starting fluid from a parts store and spray it around the intake plenum, pretty much anywhere you think the leak might be. or you could pay a shop to do it for you with an air compressor.
KhanArtisT is offline
Old 08-25-2006, 03:16 AM
  #22
Sumospeed #O.G.
SlowLS's Avatar
You have a JDM B16 right? Then you have a FITV unless you are bypassing, which may also be your problem.
SlowLS is offline
Old 08-25-2006, 10:10 AM
  #23
snozepp147's Avatar
snozepp147 has disabled reputation
SiR 1 has an FITV? i switched out the throttle body for an ls one because my old throttle body had a broken map sensor nipple (the ls TB doesn't have an FITV). the old one didn't have an FITV either tho..
snozepp147 is offline
Old 08-25-2006, 10:17 AM
  #24
Speak&Spell Anyone?
Cpt. Non-Spell's Avatar
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
sounds like you have a obd1 motor in a pbd2 car maybe?
Cpt. Non-Spell is offline
Old 08-25-2006, 10:23 AM
  #25
braap braap
Jarrod's Avatar
Coolant burp'd properly?
Jarrod is offline
Old 08-25-2006, 06:08 PM
  #26
snozepp147's Avatar
yeah obd1 motor in obd2 car with the conversion harness.
i was having to refill the coolant at first after every time i drove, but i just drove 3 hours to north carolina for college and it didn't affect the coolant level.
ffxcntyproblm
08-16-2008 11:43 AM
rotaryking
07-02-2008 05:26 PM
boostedteg
08-13-2007 05:23 PM
pasty
10-03-2006 07:04 PM
00CivicGirl
04-13-2005 06:06 PM
Quick Reply: idling too high, please help
