intake manifold question
ratty
i got a 91 dx hatch with stock d15 motor i got a intake manifold off a eg from a friend but im not sure what all to do i got everythinmg just about hooked up accept for the wire harness i dont really understand, what do i have to do to get the sensors and enjectors all hooked up so anyone that could help me or could tell me what i need or need to do would be much appreciated thanks....
ratty
やくざに成りたい
ratty
Re: intake manifold question
やくざに成りたい
search on google for dpfi to mpfi and look at as many tutorials until you find the one that makes the most sense to you. its kinda hard to explain how to do it unless you see it. good luck
ratty
ya everything makes sense somewhat i just suck with wiring but ill do that research alot then try n not screw anything up
やくざに成りたい
Wiring isn't so bad. Just give yourself a whole day to do it if you want it to look clean. Use shrinkwrap. Different color wires. Make yourself a chart on paper of what colors go where. Use electrical tape to bundle the wires and use conduit to make it look stock. Or you can run it into the stock harness which is more work but looks even better. Last but not least check, double check and check a third time when wiring so it saves you a headache later.
