integra issues...
integra issues...
whats good va, I got a lil issue. I've just got a 95 integra that's been pretty idle for a while. It starts up n all, but when i rev up the engine it won't go past 3500 rpms. I'm thinking it may be because the fuel line might be cluttered, but that's just me. I'm kinda new to fixing up cars n some feedback would be much appreciated.
Re: integra issues...
Sounds like it's in safe mode, check your ECU, should be under the carpet on the passenger side and count how many times it flashes. Then let us know, probablly just a bad sensor somewhere. O2 sensor may be a good guess. Does it idle or run rough?
corona connessuer
i have still yet to figure out what a "dizzy" is
Wanna Taste??
Ya know, i just stuck a 94 GSR B18 in my 99 Civic. Same problem. However, i've been thru about 2 weeks of rewiring the ECU, and im told the VTEC needs to be wired. If i figure this out, ill let ya know what i did.
Originally Posted by CHAHONDA
a little more info or being able to see the car would help. could be numerous things that could be causing the problem. clogged fuel filter, water in the gas, jumped timing, really need more info to properly diagnose the situation.
Last edited by Tha Radikal; 08-20-2005 at 05:39 PM. Reason: message sent to wrong person
