Integra ls high idle problem
![maurice24 is infamous around these parts](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![maurice24 is infamous around these parts](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
My car has a high idle problem, how can i fix it.
I'll post a video to show you whats wrong.
Radiator has been changed, value cover gasket, spark plug wires, IACV. http://www.youtube.com/watch?v=kyTXo44HyLY
vacuum leak of some sort?
coolant leak perhaps? or cooling system blockage?
when you changed the rad did you flush the cooling system first?
When you changed the IACV did you check all the signals going to it? Could be a bad relay or something...
http://ecomodder.com/forum/showthrea...ained-967.html
basically it could be any number of things. tough to diagnose without being able to see the car and rule things out.
Maybe try hooking your MAF and intake back up first?
well the guy i bought the car from said its the tps sensor, and whenever i put my finger in the fitv hole it idles normal
Of course i do, i think i found the problem out its the FITV not the tps sensor i probably have to tighten the screw in the fitv the big white screw thing so it won't idle so high
http://honda-tech.com/showthread.php...highlight=IACV
TYPE JDM
Want to Buy / Trade ARCHIVE
03-29-2008 07:40 PM
