Max Teg Psi?
Boost (psi) is just a number, a measurement of restriction. You can blow an engine on 8psi just as easy as 20psi. Tuning is the key.
The Greddy kit comes with an 18g, so that turbo will require you to need more boost than say a bigger turbo. So in theory you could run upwards of say 15-20 at the track with race gas, and up to 15 or so on 93 but tuning has to be on point.
But remember a turbo has its limits so when that is hit the efficiency drops and that can be bad for the engine by creating more heat.
Originally posted by Insperation
So looking at the EGT gauge, what Temp is safe and whats the danger zone? And anybody know if the greddy e-manage good?
http://www.honda-tech.com/zerothread?id=163453
here is an idea of temps...
http://www.honda-tech.com/zerothread?id=171314
Would a upgraded stronger thicker head gasket make a difference?
a thicker head gasket would lower your compression and would give you more leeway from getting detonation. fine tuning is basically setting your timing/fuel curves to where they need to be to get as much power as possible out of the motor as it is in that point in time. the best way to tune the car is w/ hondata or something similiar. another option you could look at is an SMC or AFC....
Originally posted by MORE IMPATIENT
but would also require you to run more boost to make an equal amount of power than stock compression.......
I am running 10.5:1.
BlackGsR
03-02-2008 05:23 PM
