Miata - lining engine up -help needed
Old 06-15-2009, 08:41 PM
  #21
OM NOM NOM E30
JETSWU87's Avatar
JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87
Default Re: Miata - lining engine up -help needed
are the motor mounts hitting?
when we did it, we had a jack under the tranny, got the shaft in...then lowered the jack down a little at a time as the gap closed.....started a few bolts, and that was that.
JETSWU87 is offline
Old 06-15-2009, 08:42 PM
  #22
face is vanilla
Vanilla Face's Avatar
yeah, motor mounts are hitting as well. was thinking about bolting them to the car instead of the engine, but I might have stipped a hole, and i dont want to take it out to find out haha.
Vanilla Face is offline
Old 06-15-2009, 08:43 PM
  #23
face is vanilla
Also, i did the jack under the tranny all day.
Old 06-15-2009, 08:47 PM
  #24
OM NOM NOM E30
JETSWU87's Avatar
lol, well when i took the 1.8 out of the donor car, i found it was easier with one mount off to remove.
just remove one of them should give you some more side to side wiggle room. you can always bolt it back on, just jack the motor up.
If your set on removing tranny i assume you are going to take the tranny out and bolt it to the motor, then drop the entire setup in?
JETSWU87 is offline
Old 06-15-2009, 08:49 PM
  #25
face is vanilla
yes on the dropping together.
I might give it 20-30 minutes without the mounts before I pull the tranny.
Old 06-15-2009, 09:30 PM
  #26
TRIED HIS GT!
FairladyZTT's Avatar
FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT FairladyZTT
I would check a couple different things before pulling the trans. First is the clutch allignment. I had a Mercury Capri XR2... it had the 1.6 turbo motor (B6T). The spine allignment tool would alwasy be able to be crooked just a little and the trans would not go on at all.. I would make sure that it is perfectly straight.
Second. I was doing a clutch in an S2000 and you had to damn near remove the motor to get the trans out. (really shitty design!!!) Anyways. I removed the motor mounts and dropped the motor down to pull the trans.
When I was putting the trans back on the motor. There was a slight angle difference. I almost didn't catch it at first. But the engine was level and the trans was angled up just a little bit. I ended up, picking up on the nose of the engine about 2-4 inches and the trans slid right no.
So.. Long story short. I would suggest the clutch spine allignment and make sure that the engine and trans are at the same angle.
FairladyZTT is offline
91jdmef9
Part Outs
03-24-2009 09:26 AM
cole
03-18-2005 10:20 AM
MA-HALF-E
08-22-2003 10:04 PM
Quick Reply: Miata - lining engine up -help needed
