mini me timing question?
...pulls trailer!!!
Re: mini me timing question?
my god bro instead of making a fourteen page editorial about timing let some one who knows what time it is look at it and magic
Boosted F2B
how far out is the timing? if its retarded 4.5* = you have a y7/y8 gear on your z6 cam.
no special belt when doing a mini on a d16. just match t-belt to head. i.e. z6 head = z6 belt, y8 head = y8 belt.
now a d15 mini requires the belt from a d15b7, iirc.
i think it would be easier to set the block. the take the valve cover off and spin the cam until cylinder 1 was in compression stroke which to prevent from being 180 out you could take off the dizzy cap and make sure it pointing to number 1 wire. but to line it up to be dead on would be kinda difficult. but that could help you out some. i had a d15b7 block with a z6 head and i think mine was all out of wack until we finally got it. hope that helps some
low n slow
Not true, when using a 1.5 you use the z6 belt and an adjustable cam gear, its like a half tooth off. i did one before and ran perfect
