motor question
Old 08-05-2003, 08:23 PM
been around awhile.
zappas's Avatar
zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas
do you want the price for a whole turbo kit? or for just a turbo?
and you could probably do JUST the swap for about $1500.
zappas is offline
Old 08-05-2003, 08:27 PM
Hating...
JKim's Avatar
JKim has disabled reputation
i think ur either not listening to what people are saying. or youve already made up your mind...and u shouldnt be wasting space on here.
why the would you want to turbo a lsvtec? you dont sound like the person that could do one reliably..and youll be another prime example of how NOT to Lsvtec + turbo a car.
imll say this once more. If you want turbo...go a different route. If you want Vtec power...go another route. its two different methodologies. there are literally...a handful of cars that have done lsvtec+turbo succesfully.
im not trying to bust your balls or anything man...im just trying to help you out.
btw. a complete lsvtec swap on a dc2 b18b motor + a turbo setup with the proper tuning ( not shitty like you are refereing too) will cost you about 4-5 g's...doing the work yourself. 8-9g's...having someone do it for you. *rough estimate*
JKim is offline
Old 08-05-2003, 08:30 PM
been around awhile.
zappas's Avatar
Dan, you have a good point,
If this is your daily driver, and you have no clue as you say, then ls/vtec isnt the route for you....maybe you should stick to a simpler combo, something that requires less maintenance in the long run, and is more reliable then ls/vtec is.
zappas is offline
Old 08-05-2003, 08:32 PM
Bitches get Stitches
sk8rmike's Avatar
just go LS/T man if you are going to boost the piss out of it...less hassle and you can make just as much power. just get some headwork done on it...
sk8rmike is offline
Old 08-05-2003, 08:43 PM
The Comeback Kid
Nato76's Avatar
Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76
get a ZC and boost it. Cheapest route and can be made to be fast. I dont know why people hate the ZC.
Nato76 is offline
Old 08-05-2003, 08:45 PM
Blood Money
turbo9mm's Avatar
turbo9mm is an unknown quantity at this point
where is a good place to get head work done at ??
turbo9mm is offline
Old 08-05-2003, 08:54 PM
been around awhile.
zappas's Avatar
do some research.....
zappas is offline
Old 08-06-2003, 06:40 PM
JDM SiR EG6's Avatar
JDM SiR EG6 is an unknown quantity at this point
I think you should go LS/T . . I have an LS in my CRX now . . It is pretty beefy . . and once the turbo is dropped then it will be over . . blow it and then rebuilt it with reinforced internals . . but those are my plans . . just an idea . . . if you want VTEC the b16 is beefy also
JDM SiR EG6 is offline
Old 08-06-2003, 07:27 PM
been around awhile.
zappas's Avatar
b16 = tourqeless wonder.
zappas is offline
Old 08-06-2003, 07:46 PM
Spoonfed's Avatar
Spoonfed is an unknown quantity at this point
first smart thing ive heard you say man, but as far as the swap is concerned, ZC-T is the easiest way to go, direct drop in and the turbo kits are cheaper, if you think of the Greddy kit you'll be looking at 3-4 k tops for both with decent fuel management. but as far as LS-T, thats my personal choice but you have to look that its not a direct bolt in, the 95-up are the better designs, meaning you'll have to get a jdm shift linkage, mounts, and obd-obd1 conversion harness ect ect. also the turbo kits seem to be a lil more expensive, and that will run you about 5-6k
Spoonfed is offline
Quick Reply: motor question
