My car won't start.
Old 08-11-2004, 10:53 AM
twincamvega's Avatar
twincamvega is an unknown quantity at this point
Default My car won't start.
I have a 1989 Iroc-Z Camaro with a 350, and atleast once a day when i try to start it nothing happends. In order to get it to start again, i have to disconnect the battery for 10 minutes. Anyone have any idea what the problem could be? My guess is that there might be a relay somewhere between the ignition and the solonoid on the starter, and when it heats up the switch doesnt make contact. Its only a guess though, and im not even sure if there is a relay there or not.
twincamvega is offline
Old 08-11-2004, 11:05 AM
Default Re: My car won't start.
I also had to replace the ignition cylinder recently because of problems with the VATS system, i don't think that it's related though.
Old 08-11-2004, 11:07 AM
Eat me.
Slimsta Jimsta's Avatar
Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta Slimsta Jimsta
omg it's gene. ANSWER THIS QUESTION for him
Slimsta Jimsta is offline
Old 08-11-2004, 12:11 PM
takin it all
HORNY4ZORNY's Avatar
HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY
check your battery terminals, it doent click or anything??? i would check the battery cables and terminals. go from there
HORNY4ZORNY is offline
Old 08-11-2004, 12:12 PM
Custom User Title
mnchvgs79's Avatar
mnchvgs79 is an unknown quantity at this point
Does it crank?
mnchvgs79 is offline
Old 08-11-2004, 12:18 PM
takin it all
you know thinking about it , it kinda sounds like the terminal on your batter is bad, like it s not connecting with the rest of your battery, you know what i'm saying
Old 08-11-2004, 12:31 PM
hostgator.com
flow fx's Avatar
flow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these parts
My prelude used to do that.. I believe it was just worn out rusted nasty ass wires.. Try replacing the wires from batt to fusebox, and batt to tranny ground
I'd pull in to get gas, and have to sit around for 5-10 minutes wiggling the wires around..
Also if the batt is old, get one of those battery terminal cleaners that are basically brillow pads and you stick it ontop of the terminal and spin..
flow fx is offline
Old 08-12-2004, 08:32 AM
Yeah, it doesn't crank or make any noises. The interior lights and stereo will still work though.
Old 08-12-2004, 08:34 AM
Custom User Title
mnchvgs79's Avatar
Yeah I would put my money on dirty/bad connections or wires. Stereos and lighting doesnt take much power at all to run, once you go to crank it, you need a solid connection to pull that much power.
Old 08-12-2004, 12:16 PM
200HP/L
Josepi's Avatar
Josepi Josepi Josepi Josepi Josepi Josepi Josepi
Manual? Does the clutch need to be down for it to start?
Josepi is offline
Quick Reply: My car won't start.
