My g-friend's 95 2.3 dohc prelude oil leak.
Old 04-12-2006, 02:02 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
Default Re: My g-friend's 95 2.3 dohc prelude oil leak.
Originally Posted by tie fitr
What exactly do you want a pic of?
The place where you suspect it leaking....? Where most of the oil is coming from
DOHC crx VTEC is offline
Old 04-12-2006, 02:28 PM
Prelude Whore
madcatz's Avatar
madcatz has disabled reputation
why didnt you use hondabond around the entire seal?
Granted this probably wouldnt have fixed your problem, but alas its better safe than sorry
madcatz is offline
Old 04-12-2006, 03:44 PM
Full Retard
tie fitr's Avatar
tie fitr tie fitr tie fitr tie fitr tie fitr tie fitr tie fitr tie fitr tie fitr tie fitr tie fitr
Do you mean the valve cover gasket? That is all I've replaced so far.
tie fitr is offline
Old 04-12-2006, 03:57 PM
Prelude Whore
madcatz's Avatar
yeah the VC gasket, and hondabond/RTV...not one or the other....both
madcatz is offline
Old 04-12-2006, 04:46 PM
Ross's Avatar
Ross is an unknown quantity at this point
I take it oil is leaking onto the exhaust on the intake manifold side of the motor? Try puting the vehical up on jack stands an check to see if the oil pressure sending unit is leaking, may look like the oil filter is leaking. How fast is the leak, slow drip or fast drip ? IF you still are having trouble with it PM me.
Ross is offline
Old 04-12-2006, 04:51 PM
Grease Monkey's Avatar
Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey
The H23 is known to leak at the o-ring that goes between the oil filter cooler adapter (the part the filter screws onto) and the block. There is an o-ring that goes between there and it gets old and cracks and bam bad oil leak right over the exhaust. I would look into it. It's a cheap part to replace.
It's number 33 in the picture.
-Dave
Grease Monkey is offline
Old 04-12-2006, 05:05 PM
Full Retard
tie fitr's Avatar
I appreciate all the reply's guys. Here's a pic of where the oil is pooling. It is a part of the block that sticks out beyond the head and has a groove in it. This is on the back side of the motor below the filler cap. I figure it must be coming from above this point. That is why I started with the Valve cover gasket. It is leaking alot, about 1 quart per 100 miles. so oil is everywhere and kinda makes it hard to narrow down.
tie fitr is offline
Old 04-13-2006, 03:18 AM
Full Retard
tie fitr's Avatar
I posted a pic now nobody has anything to say?
tie fitr is offline
Old 04-13-2006, 03:32 AM
Prelude Whore
madcatz's Avatar
its something I would have to see in person......It might be the seals on the corner or around the cam before the cam gear....Its not below the IM, so its not leaking out of the head gasket, so it must be something up around the Valve Cover right?
madcatz is offline
Old 04-13-2006, 07:36 AM
Full Retard
tie fitr's Avatar
That's my guess. Whatever it is, it's big.
tie fitr is offline
slowgsx95
03-23-2009 07:12 PM
SlowLS
12-16-2007 04:30 PM
dodo94integra
08-31-2006 08:50 PM
94_CRVtec
08-24-2005 02:32 PM
Quick Reply: My g-friend's 95 2.3 dohc prelude oil leak.
