my teggy i think is done.
Old 11-04-2008, 04:24 AM
Old School Beast
PoS hYbRiD's Avatar
PoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these parts
Default Re: my teggy i think is done.
I am thinking distributor. They take a shit often. Sounds like your problem.
PoS hYbRiD is offline
Old 11-04-2008, 05:53 AM
Digital Life
83Stang5.0's Avatar
Check your dizzy and the sort first. Make sure there isnt any fluids coming out of the exhaust manifold(water/oil). From what you've said, it could be almost anything. GL
83Stang5.0 is offline
Old 11-04-2008, 06:31 AM
FA SHOW's Avatar
FA SHOW FA SHOW FA SHOW FA SHOW FA SHOW FA SHOW
maybe just the coil in the dizzy.integra dizzys are dime a dozen bro.
FA SHOW is offline
Old 11-04-2008, 09:37 AM
NAZI mod
BAN HAMMER's Avatar
Sounds like you just ran out of gas?
I would go with the majority of what everybody is saying though, check the distributor.
BAN HAMMER is offline
Old 11-04-2008, 09:45 AM
Zombies found Waldo
buugiewuugie's Avatar
Sounds like a fuel issue. As stated. I'm thinking fuel pump.
First check to see if you have fuel.
Then check to see if you are getting fuel at the fuel filter.
If not I would say check your fuel pump relay if it has one. Then the pump itself
buugiewuugie is offline
Old 11-04-2008, 10:07 AM
Blah!
flat's Avatar
flat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these parts
replace the dizzy put a hundred it will crank right up unless indeed the timing belt did break
flat is offline
Old 11-04-2008, 10:29 AM
bmw-m's Avatar
bmw-m has disabled reputation
same thing happened to my teg last winter.. the cat was clogged..
when it was cold it would start, but once it started to warm up it did the same thing urs is doin..
drop the exh. and try to start it up (provided u have already checked for fuel/spark)
bmw-m is offline
Old 11-04-2008, 11:06 AM
27psi???'s Avatar
27psi??? has disabled reputation
igniter in dizzy went bad would be my first thought
27psi??? is offline
Old 11-04-2008, 11:47 AM
Mecheng88's Avatar
Mecheng88 is a jewel in the roughMecheng88 is a jewel in the roughMecheng88 is a jewel in the roughMecheng88 is a jewel in the rough
Or you could just take the timing cover off to make sure the belt is still attached. Remember, you dont want to go cranking on a honda motor like that when there might be a broken timing belt.
Mecheng88 is offline
Old 11-05-2008, 05:54 AM
やくざに成りたい
atmdc's Avatar
atmdc has disabled reputation
rotor in the distributor, happened to me bout a year ago
atmdc is offline
Quick Reply: my teggy i think is done.
