my teggy i think is done.
Old 11-05-2008, 07:09 AM
  #21
NOt rep'n the g1teg
popwars123's Avatar
popwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond repute
Default Re: my teggy i think is done.
check the screw for the rotor on your distributor..those come out often
popwars123 is offline
Old 11-05-2008, 07:14 AM
  #22
Digital Life
83Stang5.0's Avatar
On a D series, yeah all the time. Not as much for B series, but obd-0 they are infamous.
83Stang5.0 is offline
Old 11-05-2008, 07:33 AM
  #23
Huntin Dropa ForLife
RPRacing's Avatar
RPRacing has disabled reputation
check:
-Check your fuses under the hood
-Check your fuses under the dash
-With the doors shut, turn the key to the "On" Position without starting the car. Listen for your main fuel relay to click. It is located below the dash in the driver's kick panel.
-With the doors shut, turn the key to the "On" Position without starting the car. Listen for your fuel pump to make noise (it is located under the center of your rear seats, but you should be able to hear a slight humming noise for about 2-3 seconds while it primes the system.)
-Pull your valve cover off to make sure your Tbelt is still attached
-Remove your distributer cap to make sure the rotor button is still attached
report findings
RPRacing is offline
Old 11-05-2008, 09:43 AM
  #24
#1mostwanted's Avatar
#1mostwanted is an unknown quantity at this point
check your distributor aswell
#1mostwanted is offline
Old 11-05-2008, 10:50 AM
  #25
braap braap
Jarrod's Avatar
Originally Posted by RPRacing
check:
report findings
Someone with some actual car knowledge.
Come back to use and report findings. From my experience(and lack of your details) it sounds like the timing belt or it could the distributor igniter and/or coil.
Jarrod is offline
Old 11-21-2008, 06:32 AM
  #26
teg91boy's Avatar
teg91boy has disabled reputation
if all else fells check your ecu happened in my da one day when i hit a hard bump.. fried the ecu somehow...
slammed on 17'' black on black
teg91boy is offline
Old 11-21-2008, 06:49 AM
  #27
My Hatch Is SLOW
soon2bboostedls's Avatar
soon2bboostedls has disabled reputation
ignition module would be my guess. same thing happened to me when i was at nopi in rockingham a couple of years ago. car would just crank and crank and crank and never turn over. i had to but one down there. that was $100 but it fired right up
soon2bboostedls is offline
Old 11-21-2008, 07:01 AM
  #28
accuracy1's Avatar
accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1
Does it sound VERY different when it turns over? Kinda quick with a different pitch, or the same just won't start?
Kinda diff,probably=broken TB
Same prob=Distributor/parts of dist
good luck
accuracy1 is offline
90_b20z_vtec
12-24-2008 07:51 PM
90_b20z_vtec
09-18-2008 07:12 AM
90_b20z_vtec
Want to Buy / Trade ARCHIVE
06-20-2008 10:30 PM
jdm12
02-06-2008 05:30 AM
Quick Reply: my teggy i think is done.
