Need Help with 1990 Accord Ex (F22)
green box is back!
![DonVizMe has much to be proud of](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![DonVizMe has much to be proud of](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Ok well I checked the link. It looks like I got a 6.... 1 (with long pause)......then 7.
I cleaned IACV w/ throttle body cleaner before and did again for good measure. Still same issue, I looked at the codes tHe codes too. But I'm working from my phone. Just trying to figure this out.
Thanks for the link "laser" and I am doing what I can with my phone.
Google something like "Honda OBD0 codes" and you'll find thousands of links with the list of codes.
Like this one: http://ef-honda.com/ben/ECUcodes.php
green box is back!
Went to the site, found all 3 codes! This is going to be fun.
6: ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
7: TPS (Throttle Position Sensor)
And it looks like the long one may be an 02 sensor, or is it just a break to distinguish between codes?
It may be 61 and 7, because 61 is also an O2 sensor code. You're the only one who can interpret the codes as they flash out though. Regardless, you know that the O2 sensor needs to be fixed, so fix that and then see how the codes change.
green box is back!
Ok well I will check that. The led flashes 6 times stops then a long single flash, then 7 more flashes. So that's what I am not sure of. Going to replace the o2 sensor and go from there I suppose.
Thanks again for the help.
