need help....
#21
Chicken Little
![ruger988](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![ruger988](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
[/U][/B]
i would check what he said first about the coolant that is true and will determine if it is the heater core casue if you do have coolant and not water in your radiator and the heater core is leaking then it will leak coolant . not water unless you have water in your radiator.then that will tell you if its the back up tube fro mthe ac or the heater core
#24
Chicken Little
I'm not a Honda guy so I'm not going to give you any kind of a firm answer, but you def. don't have anything to worry about heater core wise if that's all the water that you're getting.
EDIT: Is that the fan/blower motor/ whatever you want to refer to it as?
#26
Chicken Little
It's obvious that's where it's coming from. Given the clarity of the water it's definitely not the heater core, even if your cooling system was pure water it wouldn't be that clear. It's got something to do with your a/c system, it's backing up somewhere. Is that a wire loom or a drain hose coming off the bottom of that unit just to the left of the plug?
#28
Chicken Little
#30
![b16bomber](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
mike its the heater core had to replace it on the hatch when i got it, wet ass antifreeze smelling shit, gotta remove the whole dash though , holla bro
