Need help fixing brake problems
Re: Need help fixing brake problems
Im ordered the master cylinder today and will change it tonight and get back with you guys as soon as I change it thanks.
Originally Posted by "SI"ngle Cam
2 bolts and 2 brake lines....make sure you use a line wrench so you don't strip them. If you want some help pm me.
Die reinste Bösen.
make sure to bleed the shit out of the system once you get that new master cylinder... air in the lines can also cause a shitty pedal.
THANKS PEEPS I CHANGED THE MASTER CYLINDER AND MY BRAKES WORK GREAT BUT I STILL HAVE THE ABS LIGHT ON DOES ANYONE KNOW WHAT IT COULD BE? ONCE AGAIN THANKS FOR THE INFO.
Die reinste Bösen.
alot of times thats when an ABS sensor has gone bad, or it could be just acting funny... take the negative terminal off of your battery for 30 min and then put the terminal back on. sometimes that will fix those little quirks by resetting the ECU.
