need help indef. parts
k i ha 3 bar map sensor i dont know shit about it doesnt seem to have a name brand on it just the numbers as follow
on the white sticker:
020906 1034
part 12223861
lot g2dxf4
2nd i have these injector and dont know what cc or anything they are i found the followin link on the injector but having hard time understandin what cc they flow at http://www.bmotorsports.com/shop/pro...roducts_id/448
they are siemiens deka and have 107961 on them
i have searched google and am having hard time finding any info bout the followin if you guys could help would be very appericate
020906 1034
part 12223861
lot g2dxf4
Re: need help indef. parts
Convert lb/hour to cc/min. It says right there that they're 60lb/hr.
There is plenty of info on those under the specifications.
That's really funny, I'm a MotoTron employee (there were only 60 of us before the company got bought last year, now we're not MotoTron anymore) and we only sold those injectors to a few companies so it always makes me laugh because they seem to be everywhere.. They were private labeled so our injectors were only a very small part of all of the Deka IVs out there, but it's really funny that people talk about "MotoTron" injectors. We make ECUs; the injectors are just a support part that we had private labeled to sell to certain customers. It's too bad your set doesn't have our logo on it, that would make my day.
The 12223861 number is a GM part number, and that's a standard GM map sensor case.
And look, it's your MAP sensor on the exact same website.
http://www.bmotorsports.com/shop/pro...oducts_id/1584
i decided not to run the map sensor im only running 10psi and i understand converting that but when i gettin tuned he asked what size injectors and i dont know what to say ? so i need that number
Tell him 60 lb/hr. That's what size they are. If your tuner can't either use that number or convert it to whatever units the tuning software uses, I'm not sure I'd let him touch my engine.
LOOK! The info you need it right on the injector page that you posted a link to!
Come on man, read more closely..
Features:
* Genuine, reliable Siemens Injectors
* Excellent response characteristics
* Robust Design
* High Impedance
* Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
* Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
* Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
* Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
* Gain: 0.11ms/mg
* Offset: 0.055ms
* Turn on time @ 14VDC: 1.14ms
* Turn off time: 0.85ms @ 600KPa
* Connector: Bosch EV1
* Series: DEKA 4 ( DEKA IV )
* Orifice Type: Multi-orifice
* Spray Pattern: 30 Degree Spray Cone
* Factory fitted with Viton upper and lower o-rings
Features:
* Robust Design
* High Impedance
Specifications:
* Gain: 0.11ms/mg
* Offset: 0.055ms
corona connessuer
how does the rep thing work anyway? i dont even know how to use it????
also that should be a grand national map sensor. commonly used in boosting applications
