Need some help please...
#62
Slammedxpert
Re: Need some help please...
That's not actually possible. Unless you had an injector leaking very badly and the pressure was turned up pretty high on the FPR. Technically that could cause fuel to puddle in the manifold but it would have to leaking CONSIDERABLY. This is since the FPR is mounted on the fuel rail. Was the vacuum light connected to the AEM FPR? If it wasn't them it was acting as if it was at full throttle all the time.
Aeromotive FPR's for the Fucking winn
#63
Yeah, I took it to Shad at Accuracy...he hooked me up. Guess I'll run a stock FPR for now. I'll check out the Aeromotive FPR's in the near future.
#64
Leave the stock one on, there isn't any reason to need an aftermarket adjustable regulator for the setup you have. Glad everything is working properly though.
#65
Dont guess, diagnose
That would cause it to run at the max pressure it is set too all the time. Do you have a fuel pressure gauge installed at all?
