Need some help (SR20DET)
Iridium V
Re: Need some help (SR20DET)
I may be a little late on this one, but are you running an open air compressor bypass valve, if so, this may be causing the car to stall when coming to a stop or while driving and shifting into neutral. I was dealing with this problem on my S13.
I <3 Hikki Chan!
I just upgraded my injectors, turbo, and turbo manifold on my car, and I have an SAFC 2 for tuning. Everything seems fine except when I come to a stop, the rpm drops and sometimes stalls the car. I tried messing with the dec. air on the afc, but nothing seems to be working. Anyone know what I can do? Or anyone that can help/tune it for me in the central area?
Thanks,
Alex
Thanks,
Alex
It bogs down and stalls. It depends how much air is being vented.
an SAFC should not be used to tune your car to run larger injectors. All it does is fool the ECU into thinking a different amount of air is coming in. It still uses the existing map in the ECU but just a different location since the air data is tampered. Becauese of this, it uses incorrect ignition timing and your risk damaging your motor in the higher RPMs with more load.
Enthalpy, EFI, Hybrid Dynamics, and Jim Wolf all sell ROM tuned ECUs. They come with a base map for differnt injector sizes and MAFs.
