Need some wire tuck advie!
Old 07-25-2010, 06:10 PM
Hi
Integra2Be's Avatar
Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be
Default Re: Need some wire tuck advie!
Originally Posted by 連続注入
the Purge valve is on the charcoal canister. You shouldn't be messing with the fuel pressure regulator, there is no valve for it either, it is the "valve".
As far as codes I'm sure there will be emissions related, which ones I dont know. Not only that the charcoal canister keeps fuel vapors trapped there until the vehicle is running and then pulls that vapors into the engine to be used.
sorry, miss red the diagram. and i ment the evap contol and fpr control solenoid. see pic below
Spoiler
Integra2Be is offline
Old 07-25-2010, 06:56 PM
E F
E F's Avatar
E F E F E F E F E F E F E F E F E F
what you're wanting to do is not difficult at all but pretty time consuming, I went through the same process over the winter and spring to re-do my bay while I was building my motor... I'll be happy to share pictures with you if you think it might help you.
I removed the charcoal canister altogether, I haven't had any issues or anything and don't expect any , really... I don't have carpet or anything in my interior, until I had all the part I needed for my build I re-did my interior as well. It was completely disassembled, sound deadening material removed and pretty much stripped to the metal, then primed and painted. I wanted a really clean look inside as well so I removed all three hard fuel lines and replaced the feed and return line with steel braided braided lines running through the frame of the car, the third one os connected to the charcoal canister, I simply got rid of it al together and at the gas tank end I just placed a small filter.
I went to Advance auto parts and bought a spool of Hard brake lines, it was 25' for about $20.00, my car (93 gs-r) had abs, I removed everything related to it and re-routed new hard lines, from the master cylinder through a small whole on the firewall to the proportioning valve mounted on the inside of the firewall, then from there through the passenger and driver side frame, the length of every line to each wheel is exactly the same. I would highly suggest that! some 3/16" Stainless hard line and a Harbor freight flaring tool did the trick for me...
For the fuel I did exactly what the other guys were telling you, use an inline filter. Mine is mounted on the inside of my firewall with some brackets I made and rubber washers.
I know this is a lot of information here, man... feel free to contact me if you want some additional help. Like I said, I' m happy to share some pics...
E F is offline
Old 07-25-2010, 07:09 PM
peaches
b16EFsedan's Avatar
nice one here
http://forums.g2ic.com/showthread.ph...ight=wire+tuck
b16EFsedan is offline
Old 07-26-2010, 11:18 AM
Hi
Integra2Be's Avatar
thanks man. pics would be nice you can just pm them to me. but where are you located? any extra hands wont hurt if your down to help? hah
Originally Posted by b16EFsedan
saw this and book marked it already. hah. but its only for the wire harness which is easy and i know how to do.
Vern
08-29-2006 06:01 PM
ChristianVA
01-20-2003 12:45 PM
cokinut
01-07-2003 04:28 AM
SLO-4G63
01-01-2003 09:16 PM
Quick Reply: Need some wire tuck advie!
