Not sure how to title this..
Old 11-18-2008, 06:39 PM
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
Default Re: Not sure how to title this..
Originally Posted by TurboEGferio
Sometimes when my car gets boost in third gear the check engine comes on then it will not get full boost, but when I try it again it will! It only does it sometimes but I dont know where to even start. I have a S100 program if that helps
What map are you using? Was it made for your setup (i.e. tuned for your setup)? I'm assuming the Hondata or OMNI 4 bar map then?
DeFunk is offline
Old 11-18-2008, 06:44 PM
eclispegs2008's Avatar
eclispegs2008 has disabled reputation
It does sounds like a map sensor related problem almost, try to check the code when it comes on if itll stay on. Here is what boost creep is to settle it, It indeed boosting past what the controller is set. Just as saying boost is creeping past your desired setting. Its cause by the wastegate not being large enough to flow the exhaust out for whatever setup its on. Solution, bigger wastegate
eclispegs2008 is offline
Old 11-18-2008, 06:50 PM
DeFunk's Avatar
Wastegates aren't the only cause, though the most common.
DeFunk is offline
Old 11-18-2008, 09:00 PM
braap braap
Jarrod's Avatar
My car does this if it isn't warmed up.
It's called retardation mode.
Any retard who gets on their car when it is cold deserves to eat steeringwheel and see CE.
So. Does your car warm up?
Jarrod is offline
Old 11-18-2008, 09:49 PM
DeFunk's Avatar
Boy, wish I were good at photochopping, I'd find me a picture of the MSD 6BTM retard knob and do some editing to fit your above... if only..
DeFunk is offline
Old 11-19-2008, 05:05 PM
weldmatic's Avatar
weldmatic has disabled reputation
+1 for a boost/ map sensor issue....
on a stock sensor i used check valves, but its prolly not really gonna help you.....
spray some naws on it
weldmatic is offline
baller/dickbutt#69
nftuatn's Avatar
dont listen to weldmatic
edit.fuck i was trying to get it in before you...lol
nftuatn is offline
Old 11-19-2008, 05:38 PM
weldmatic's Avatar
ha ha you penis
LShatch59
10-08-2008 11:18 AM
boostedgst97
03-09-2007 02:30 AM
Quick Reply: Not sure how to title this..
