o2 wiring problem?
Old 08-16-2010, 07:38 AM
WannaBboosted's Avatar
WannaBboosted has disabled reputation
Default o2 wiring problem?
ok i just bought a new lambda o2 sensor for cheap. i got it all out and everything just need to do the wiring. the new o2 sensor has just a black and a white wire. they stock honda adapter still has the 2black 1 white and 1 green what goes wherE?
WannaBboosted is offline
Old 08-16-2010, 08:40 AM
Default Re: o2 wiring problem?
The O2 sensor you bought is probably just a crappy one wire O2 sensor, so one wire is signal and the other is ground. The O2 you have in there already (the 4 wire) is a heated O2 sensor, which generally works a lot better. I would really spend the money and get a decent replacement for the stock one, because it is one of the most important sensors for proper engine operation. Usually cheap universal replacement O2 sensors are absolute garbage and don't work very well.
Old 08-16-2010, 09:04 AM
but could i still use that one?
Old 08-16-2010, 05:05 PM
If the ECU is looking for a heated O2 sensor, you'll probably get a heater circuit CEL. You should really buy the right replacement for that if you want everything to work properly.
Old 08-16-2010, 05:27 PM
TurboPipingSystems
thermal's Avatar
what year is your Honda?
thermal is offline
Mdotmech
01-03-2006 06:53 PM
97gsT01gsR
10-30-2005 01:55 PM
gear
02-26-2004 12:47 PM
Carter
09-10-2003 10:01 AM
4BangerCivic
07-06-2003 10:58 AM
Quick Reply: o2 wiring problem?
