obd2 dizzy obd1 motor problem?
DESTROYS DONUTS !!
Re: obd2 dizzy obd1 motor problem?
You guys are both misinformed, and are both ignoring the fact that many/most JDM OBD2 engines don't even have the crank fluctuation sensor, which is what you're calling the "crank position sensor" that is on the block.
All critical engine position sensors are in the distributor.
Yeah, it's a little odd because many engines have their crank sensor where the Honda crank fluctuation sensor is. Well, many engines don't have a distributor at all or don't have any engine position sensors in the distributor. So yeah, slightly different than a lot of stuff.
The crank fluct sensor is used to compare differences in crank acceleration with the crank position sensor in the distributor. It's a strange thing to need but it's very useful when the other sensors aren't direct mounted to the engine. I have no idea why Honda clung to that design for so long, but it probably has something to do with fast/cheap engine assembly.
da dragva kokopelli
i was thinking that the ecu was looking for the sensor and it was not present, yet i didnt realize he said it was a chipped ecu until i just re read the post.
Being chipped doesn't have anything to do with looking for a sensor that wasn't there. It wasn't looking for a sensor that wasn't there, it's looking for sensors that are exactly where they're supposed to be. Chipped or not, the ECU can't run the engine without a crank and cam position sensor, which in any case are always in the distributor.
Ok so I'm alittle confused now because More Impatient and Nagger are telling me to change to an OBD1 dizzy but Jarrod is telling me thats its just my wiring thats the problem...Which one is the correct fix? If its the pin out thats the problem can someone put a pinout up so i can check it again just to make sure....and if its the dizzy that needs to be switched i need jto buy an obd1 vtec dizzy from someone cuz my wires for my pickups are all coroded in my old one.
You can use an OBD2 distributor. That's why you can use an OBD2-OBD1 harness if you want to use an OBD1 ECU for tuning, etc. It's plug and play. You have a wiring problem or something similar.
to wire it up correctly simply pin out each circuit from the ecu to the dizzy connector using a multimeter (set up to measure continuity of course)..
yea its kind of a PITA but it will only take 15 mins..
JePrOx_BoNeRYo
Want to Buy / Trade ARCHIVE
09-15-2008 08:39 AM
