oil bearing clearance question
Old 10-16-2008, 06:07 PM
B20 VTEC
frankinstine's Avatar
frankinstine has disabled reputation
Default oil bearing clearance question
i have a jdm b20b or honda crv motor. my question is about oil bearing clearances i know the stock should be between .0015 and .0020 with .0020 being service limit. But when i plastigauge it with a stock new bearing i come out with .004 to .005. What oversized bearing should i go with. Any help would be nice.
frankinstine is offline
Old 10-16-2008, 08:40 PM
RIP DRAGVA-2016
NasTHatch's Avatar
Default Re: oil bearing clearance question
ACL makes oversized bearings, and they are nice bearings, i just ordered standard size rod and main bearings for $109.00 and it took 2 days to get and you can find them if you Google it,just make sure they have the bearings in stock and don't have any negative feedback, because the first set i ordered were on back order for 2 weeks and they gave me no notification,so i canceled and re-ordered with another company..
NasTHatch is offline
Old 10-16-2008, 10:56 PM
ChokolAwt's Avatar
ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt
the stock block comes blueprinted from the factory. So unless you're running an aftermarket crank, you should be good with stock... no need to plastiguage...
ChokolAwt is offline
Old 10-17-2008, 11:10 AM
B20 VTEC
i had spun a bearing on the number one rod and like i said before i am coming up between .004 to .005 on a new set of stock rod bearings when i should be coming up with .0015 to .0020. just trying to figure out what oversized bearing to go with.
Old 10-19-2008, 01:30 PM
micheal8042's Avatar
micheal8042 has disabled reputation
is this clearence just on this one rod and if so here is a color code oem bearing thickness chart with all the thickness of all the bearings. hope this helps
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586
micheal8042 is offline
2kSi
12-24-2008 08:09 PM
Rueben
06-24-2008 06:04 AM
AdubsGSR
01-18-2008 10:31 PM
integra-t
11-19-2007 08:59 PM
Quick Reply: oil bearing clearance question
