oil pan gasket
SAY IT WITCHA CHEST!
I Love to Hate
Re: oil pan gasket
drain oil
take off the header
remove pan bolts and nuts
remove gasket, clean it up, put on new gasket
replace pan and bolts
hand tighten the bolts and nuts in the torx pattern (be easy)
replace header.
crack a Stone Pale Ale
take off the header
replace header.
Re: oil pan gasket
sorry kinda new at this
Re: oil pan gasket
tighten one bolt down, then tighten one directly across from it, and keep continuing that pattern. dont tighten them all the way down the first time, lightly tighten each bolt down in that pattern, then go back and re-tighten them all.
Re: oil pan gasket
yeah, just tighten them down enough to seat the oil pan. once it's set and the bolts have all been slightly tightened, give each bolt a quick turn to tighten them down fully. but like i said before, be really careful not to over-tighten them...they break very easily.
