Pic Of Problem Help ME
#24
Re: Pic Of Problem Help ME
the pcv thats crazy but i know the cam seals are leaking alittle but if they were leaking bad my timming belt would be oily its dry i think its the crank seal its real oily on the back of the oil pump and getting all over the alternator and under the car when i drive but if i stop and loook its just staedly dripping down
#26
if the cam seals were leaking would it be dropping down and comming out by oil pan its dripping down when the car was running right in the middle of the timming cover
#27
if it was the cam seals leaking that bad my timming belt would be oily and it wouldnt be dripping down so far and hitting the alternator look on the oil pump and alternator how oily it is its comming from somewhere over there
#28
Well from thoroughly looking at the pictures, you have a oil pump 10mm bolt missing at the end of the oil pump. Which is letting oil blow by your o-ring and spray all over your altenator. Maybe you should check to see if there is an o-ring and then put a 10mm bolt there and you are done......
