Problem with ZC Swap
after my girl did her ZC swap she threw a code 9:
Code 9 - No. 1 Cylinder Position Sensor -
It's the third sensor in the dist., and it detects the position of the No. 1 Cylinder, as the base for the Sequential Injection. It can also be located on the camshaft of DOHC engines.
CYP sensor is mounted on the exhaust cam on the ZC.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up to 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing by itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
after replacing both the dist. and cyp sensor it still throws the 9 code after reseting!
ima ty the cam timing next!
but gemme some thoughts!
plz!
plz!
I dont know that much details about honda since im not a owner of one. BUt might be CPS sensor that will fuck alot of cars up and give all sortas of codes also it will run but its hard it hesitats to start sometimes...If at all
Phil for President!
well its my car, and SirDead up there has been drivin it to do some work on it at his skool, and he sez it will accelerate to 4k rpms and sounds like it is accelerating faster but does not move any faster, and its like in limbo mode, but its not. if that makes any sense. HELP
maybe an ecu wiring prob too? jus a thought
chk the throttle position sensor, in the t-body. it has malfunctiond. its tricky, why you got the code u did, butt 99.9% sure its the TPS. u idleing high?
www.kutza.com
www.kutza.com
