Problems after manual conversion
Re: Problems after manual conversion
Granted some of your info was helpful but the way it was delivered was unneeded. Also the fill plug is on the side of the trans above the axle. And once again answers should stay on topic. Comments about someones mechanical experience has nothing to do with the topic. By the way tell your/my kids that I said it is OK to play in the yard since Im never coming back to their mom ever again!
Sorry I get the last word on this one chump since this is the end of this post!!
Hey guys maybe you can help me out. First I converted a 95 hatch from auto to a manual using a CX trans. I used some delsol shift linkage and clutch pedal with master cylinder. I had to cut and re-weld the linkage for proper positioning. The problems that I have are that the engine is sitting uneven. It is sitting higher on the side where the trans mount is. I bought a new mount from Napa because my auto mount wouldn't work. Also I hear a noise from the trans (like a grinding noise) when accelerating. I think it may have to do with the engine alignment. Also I literally had to force the mount into place on the frame rail. Is there a special mount I am supposed to use? Also is there maybe something I am missing as far as the swap goes? How do I do away with the neutral safety switch? How do I wire in the clutch inhibit switch and the back-up light switch? Any help would me appreciated.
Scott
Also, one more thing, I have an open hole in the top of the trans where something is supposed to screw into. I dont know what it is but it spits oil out while driving.
Scott
jesus says you fail.
/life
