Profec B II Gurus need you help.
Re: Profec B II Gurus need you help.
I think the spec2 has a lot more potential once you get it to work for you. With that type S I don't see it having a warning or limiter setting. Don't get me wrong I know what your saying too. You don't really need a warning and limiter if the unit you are using can set your boost to the proper level every time.
So you have this unit now? If so do you experience any boost spikes with it? How long did it take to tune to your desired psi level?
I still can't get this thing to work...a setting that will workin the morning will not work when i get off work in the evening. Almost like its temperature sensative.
Would someone in the VA Beach area be willing to help me out tuning this?
I dunno, it's still a POS.
i havent had any problem with mine controlling boost under temperature differences...
holds the same psi, just when its hot out the car doesnt run as smooth....or as strong. it gets better traction though...
maybe it has to do with where I have it located? Hey boost Junkie, when do you have some free time? I would like you to check this out and see if you could get it working. I have done research and messed with this thing for over 3 months now. I like to try every option before giving up. Let me know when you have some free time.
