question about no spark, and ignition Car-1995 240sx
Old 12-07-2010, 03:58 PM
sidelight's Avatar
sidelight has disabled reputation
Default question about no spark, and ignition Car-1995 240sx
question about no spark, and ignition .car-1995 240sx
My s14 cranks, but don't start. If I take a plug wire out, put a spark plug on it, crank it and I see no spark/blue color on the tip of the plug.
Then does this mean that the ignition/or distributor is no good?
sidelight is offline
Old 12-07-2010, 04:08 PM
baller/dickbutt#69
nftuatn's Avatar
Default Re: question about no spark, and ignition Car-1995 240sx
it means its not gettting fire...could be the dizzy,or could be crank/cam sensors..etc...
nftuatn is offline
Old 12-09-2010, 12:57 PM
Slomar's Avatar
Slomar Slomar Slomar Slomar Slomar Slomar
Did it just stop working? Have you checked your cap and rotor? It kind of sounds like a ignition coil. See if you can burrow an ignition coil from someone and try that.
Slomar is offline
Old 12-09-2010, 03:29 PM
pnoise_dc's Avatar
pnoise_dc has disabled reputation
coil is bad get new dizzy
pnoise_dc is offline
Old 12-13-2010, 07:19 PM
om nom nom nom
junk40sx's Avatar
junk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these partsjunk40sx is infamous around these parts
when you put the plug in it did you touch the plug to a ground?
if not try that.
if it still has no spark check the dizzy and rotor like said above..
junk40sx is offline
om nom nom nom
junk40sx's Avatar
ps what motor is it?
junk40sx is offline
bensrex
05-04-2005 06:41 PM
Hondasi88
11-05-2004 06:53 AM
ProjektHatch
10-31-2004 07:27 AM
Turizmo01
03-27-2004 12:43 PM
spec
06-08-2003 07:10 AM
Quick Reply: question about no spark, and ignition Car-1995 240sx
