randomly goes into limp mode
Old 07-06-2009, 12:41 PM
Digital Life
83Stang5.0's Avatar
Default Re: randomly goes into limp mode
Originally Posted by ChokolAwt
how can you check the codes if the led isn't flashing... it's just solid.
i redid my mpfi wiring and made it look cleaner as well as wiring up my lc-1 and i think i fixed it? i test drove it and it worked fine... my only concern is that it was always random when it failed on me, so i guess i'll see...
Is the LED still solid? It shouldn't be on unless there is a problem. The LED being solid isn't an actual code, but it is a symptom like I said.
83Stang5.0 is offline
Old 07-06-2009, 01:10 PM
ChokolAwt's Avatar
ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt
no, it went away... lol
a solid led is code 0, which means faulty ecu... hondas are all alike in that they can run off just a few sensors (tps, etc...) with rev limit ~3k... it's like enough to "limp" your car home haha
but now it's working fine... lc-1 was showing 9-14 afr while i was driving, so im not sure if the ecu has gathered enough info to start using the o2 sensor yet... no code though... weird?
ChokolAwt is offline
nosediv3
12-05-2008 12:56 PM
jaccord95
07-31-2008 09:14 PM
JAPCO
02-24-2007 04:49 PM
ONYX787
11-07-2005 03:14 PM
xk84f9ds
10-17-2004 05:10 PM
Quick Reply: randomly goes into limp mode
