Red line on a 1995 D16Z6 Honda motor
Old 12-07-2006, 04:06 PM
I drive a coupe
Hatch Man(GsR)'s Avatar
Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR)
Default Re: Red line on a 1995 D16Z6 Honda motor
just because your tach reads something doesnt make it accurate. The ecu itself is programmed for 7200rpm as people have said before. Unless there is a problem with your distributor wiring it will rev to 7200 when datalogging from the ecu..
Hatch Man(GsR) is offline
Old 12-15-2006, 01:53 PM
olengrumpy's Avatar
olengrumpy has disabled reputation
hey..
that 13.4 naturally aspirated I assume..
What mods did you do to get those times??
olengrumpy is offline
Old 12-15-2006, 04:48 PM
ooooooooooowwweeeeee
Don_is_Rad's Avatar
Don_is_Rad has disabled reputation
Originally Posted by olengrumpy
hey..
Whose this directed to?
Don_is_Rad is offline
Old 12-15-2006, 10:04 PM
sohc_mshue's Avatar
hey..
VTEC
sohc_mshue is offline
Old 12-21-2006, 10:07 AM
sohc4life's Avatar
sohc4life has disabled reputation
yo its 7200 i have the p28 in my car but my friends line at 8200 so it all depends on your car
sohc4life is offline
Old 12-21-2006, 07:04 PM
I drive a coupe
Not directed at sohc4life...
a lot of people fail to grasp the concept that a stock ecu will set the rev limit at 7200 rpm. If you think your car rev's higher, either A the ecu is chipped with a higher rev limit, B there is a problem with the tach signal wire from the distributor, C there is a problem inside the distributor itself, or D there is a problem with the tach in your gauge cluster.
Period.
hey..
I dont think you realize how difficult it is to get a stock block SOHC coupe with full interior into the mid-low 13's. The highest all motor hp numbers I have seen from a sohc are just under 200whp, which is nowhere near enough to get low-mid 13's in a 2500lb coupe. If it were in something like a stripped ef hatch, or crx it would be a different story...
Old 12-23-2006, 03:32 PM
justa95vx's Avatar
justa95vx has disabled reputation
OK I HAVE A 95 EX WITH A STOCK P28 IT BOUNCES THE BOX AT 7500
justa95vx is offline
Old 12-23-2006, 07:38 PM
Don_is_Rad's Avatar
Yep, thats what mine does,this thread is way old!
Old 12-23-2006, 10:12 PM
The Dude abides
1hgej1's Avatar
1hgej1 is on a distinguished road
Period.
I dont think you realize how difficult it is to get a stock block SOHC coupe with full interior into the mid-low 13's. The highest all motor hp numbers I have seen from a sohc are just under 200whp, which is nowhere near enough to get low-mid 13's in a 3500lb coupe. If it were in something like a stripped ef hatch, or crx it would be a different story...
most 92-00 civic coupes weigh around 24-2600 lbs, and that's if it's an EX. 92-95 DX coupes are as light as 22-2300 lbs. I think you got your info a little twisted there bud. Only Honda cars I've seen over 3000 lbs are Preludes, Accords, and NSXs.
1hgej1 is offline
Old 12-23-2006, 10:13 PM
nismo's Avatar
nismo nismo nismo nismo nismo nismo nismo nismo nismo nismo nismo
civic is like the same weight as a truck now?
werd.
nismo is offline
Quick Reply: Red line on a 1995 D16Z6 Honda motor
