Right Side Grind
fuck this shit
Re: Right Side Grind
step 1) purchase a jack
step 2) Remove from packaging
step 3) place under car in appropriate location
step 4) loosen lug nuts
step 5) lift car
step 6) remove wheel
step 7) inspect for broken or worn parts. start with what Kris has said, then research what all is in the front
front parts consist of wheel, tire, inner fender, fender crease/pinch weld, outer fender, liner, cv axles, half shaft, lower steering rack, power steering fluid level and hoses, outer and inner tie rods, upper and lower ball joints, wheel bearings, upper control arms, lower control arms, struts, shocks or coilovers/springs, upper damper on shock..... inspection of all these pieces would be a good start. i'll do it for twenty bux, but today is my birthday, and it would take damn near a miracle to remove me from my tv set and 6 pack.
step 5) lift car
Dickbutt #peentip
according round town
i know they are kris. lmao
alright i got the wheel off and had a look see and i didnt see or feel anything out of the ordinary.
im stumped
im stumped
Dickbutt #peentip
You might really want to have a look over EVERYTHING if you haven't foind it. I don't know much about accords, but I'm sure theyre not much different. 18's really do alot of work on such a small car's suspension. Bj's (lullz) and wheel bearings. Don;t forget to check your pads and rotorzzzzzzz
alright i have the front wheels off... again i dont see anything wrong. the bearing rubber looks worn and there doesnt seem to be alot of grease in there either.
yea i know 18s=bad. but also no money=bad too. trust me, id get rid of them if i had the cash.
if anyone thats on and lives in the Oceanview area wants to help me out in person pm me and ill give you my address. i could really use the help. need to figure this out and fix it by the end of today. (probly wont happen)
Dickbutt #peentip
Can't even afford gas
alright, local mechanic (BP on chesapeake blvd and bayveiw blvd) says its a wheel bearing going bad.
anybody have do it yourself manual?
