s13 battery relocation problem, power staying on
psycho jungle cat
Re: s13 battery relocation problem, power staying on
did you do anything for the starter? I cant remember if I did something different on mine or if i missed it on your link but I ran a separate power wire for the starter through a distributiion block. I also had the ground from the intake mani to the frame rail.
***If this makes no sense or im missing the point again please disregard im rambling on rum***
Fitty Tuckin
Fitty Tuckin
Got the car started.
I had the two wires for the auto to manual swap wrong. There are two plugs that look the same with two wires coming out. I had the wrong plug and I fixed this. Car started with no problem
I am still having the power problem though. So when I tried to turn the car off, it wouldn't shut off with the key out of the ignition. Had to disconnect the CAS for the car to shut off.
My lights, windows, headlights all stay on even with the key out. So I took the turbo timer out of the equation and layed it on the floor. Disconnected the engine harness from the chassis connection and dash connection. Turn the key on and off and the power still stays on.
Tried another ignition cylinder (where the key goes in) and still the same problem. There is a black/white wire that is the ON wire. If I ground this wire then the power will turn off. Could it be a bad relay? If so where is it at?
Did the car work properly before you relocated the battery? If you're trying to troubleshoot the swap wiring at the same time as the battery, you're not doing yourself any favors. I still think it's most likely not the battery relocation. You could still be missing a ground under the hood though. Looking at the relocation threads on some other forums, there doesn't sound like there is anything other than the battery negative on that one cable, so you've likely got a problem somewhere else.
Fitty Tuckin
I don't think it's the engine harness, because the car fires with no problem. I am going to take the dash out and check all wiring. I found nuts in the engine bay so maybe a mouse did some damage. Plus like you said maybe there is a ground somewhere missing.
I don't think its the battery relocation either.
stevearino80
12
02-08-2009 06:02 PM
