S13 KA24DE - No Power To Dizzy
![hottscennessey has a spectacular aura about](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
Oops, what I meant was you could test *for* the CAS code by installing the S13 distributor, cranking the motor so the ECU will "see" the CAS signal. The CAS detects the speed the engine is turning at by sending a signal to the ECU. The ECU "looks" for spikes in signal that are caused when an optical sensor detects light passing from an LED like source, through slots in a wheel. It looks for the 4 slots indicating each piston's TDC and 360 "sync" signals per full engine cycle.
YANKYMATE!
See, now I'm confused hahaha so I'll try to explain everything.
The block and head are S14 KA24DE, but the harness, ECU, intake and exhaust manifolds and everything else are all S13 KA24DE, including the distributor. I know that the S14 distributor has a coil under the cap, but my S13 distributor doesn't. There are four wires coming off the cap to each spark plug, and one wire going to the cap in the middle that feeds spark to the distributor. The wire comes from the driver's side inner fender, where the coil and resister is mounted. The wiring harness runs to one end of the coil, and there's only one wire that comes out that goes to the distributor. Power is making it to the coil, but nothing is coming out.
This is a picture of my bay as soon as the engine went in:
![](http://i54.tinypic.com/34dpquv.jpg)
You can see the coil on the inner fender, running to the distributor. And that's my setup. So now I'm confused, but I hope you aren't so you can explain it to me hahaha
Gotcha, that helps
The reason you're probably not getting power through the coil is because the ECU can't see that the engine is moving. It won't send an output to fire the coil if it can't detect the position the engine is in. It detects when to fire the coil using that CAS.
YANKYMATE!
Gotcha, that helps
The CAS is located in the distributor, it gives the vital information to the ECU (speed and position). The ECU controls timing, it is not a static advance system like a old school v8.
YANKYMATE!
So do you think that's a legitimate reason as to why my motor won't catch? It was running like a beast a couple hours early, I had no forewarning that it would just not start.
I'll check the ECU and coil today. Is there a way to test the distributor? And what about all the codes?
If you have a service manual it will give you step by step to test the distributor.
YANKYMATE!
I'll check the ECU, CAS, and coil today, as well as power all the relays and make sure they open and work fine. I'll let you know what I come up with
