serious sputtering
So you still have the O2 sensor CEL. Which O2 sensor are you using, and what is it supposed to be for that ECU? If you're using a 1-wire, and the ECU wants a 4-wire, you're going to have problems. This should be an easy thing to fix, so I don't quite understand what you're doing here..
i have the rywire harness and for the o2 hookup it has the 4 wire plug with only one wire in it not 4. so i took a 4 wire o2 sensor i had layin around an cut the sensor off and wired the 1 wire o2 sensor onto the plug in the same spot as the wire on the engine harness
The o2 sensor I used was on my stock motor with no codes. But either way ive never heard or seen a o2 sensor make a car kick and jump like mine does
