shifter bushing 240sx
Dtune_bb2
![NAJDMDC4 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
ok well im relatively new to 240s. i just picked up a 89 240sx with a neo rb25 swap. the guy i picked it up from had put the neo rb25 swap in with the neo rb25 tranny but put a ka shifter and i need to replace the shifter bushing cause it is very bad. so to replace the shifter bushing do i just get a rb25 shifter bushing, ka shifter bushing, or would any 240sx shifter bushing work
Which shifter bushing...? The bushing between the chassis and the shift lever, the bushing between the shift lever and the shift linkage, which one?
Administrator
![eng](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![eng](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
I'm going to assume he's talking about the plastic bushing that's on the end of the shift lever. In which case one from almost any RWD Nissan should work.
Here's the Nissan part number if you want to buy a new one: 32861
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
this is a better replacement for plastic stock unit...this is whats on mine
CUSCO brass bushing
http://www.phase2motortrend.com/cushbu24.html
CUSCO brass bushing
Administrator
CUSCO brass bushing
CUSCO brass bushing
__________________
did you get oem or the brass one? when i got my brass one on it was a little loose, but i took some pliers and compressed it on and it was good to go.
