slight clunking sound(front end)
Ghost
I'v enever heard a CV joint "clunk" though. "Click" definitely, but not "clunk". So you did my test and saw that the motor stays put when under a load?
Yeah, I did your test and the motor didn't budge any more than it should.
Now as far as it being a clunk or a click, it could be either. I'll have to let a few friends drive the car later to see which sound they think it is.
![00CivicGirl is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
must be a nissan thing..mine does it too and i have yet to find the problem and something rattles like crazy. i am guessin a heat shield but havent had time to look
Iridium V
![MGBRaceman has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![MGBRaceman has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
If the "clunk" also occurs under heard braking, check all suspension components and brackets. As the car loads to the rear and vice the front this could be causing a loose component (torsion rod) to smack the piece of chassis it's mounted to momentarily. Had this problem with a prelude.
