Smoke for under intake manifold????
Old 05-07-2009, 11:01 AM
lacedemen's Avatar
lacedemen has disabled reputation
Default Smoke for under intake manifold????
Alright today my car started over heating an i pulled over an looked under the hood an i seen a little bit of smoke coming from under the intake maifold i put my hand under it an i felt some air presure also. so I was seeing if any one might no what it may be. Its a civic d16z6
lacedemen is offline
Old 05-07-2009, 11:13 AM
cleanEK's Avatar
Default Re: Smoke for under intake manifold????
I had the same problem a while ago, my oil pan gasket was leaking and spraying oil on the cat and causing smoke to come up. Also, it could be a coolent leak, which is leaking fluid onto your exhaust and burning it cause smoke to come up.
Good luck, hope this helps.
cleanEK is offline
Needs more poke.
Tarzan Bakerada's Avatar
you only need one thread.
Tarzan Bakerada is offline
Old 05-07-2009, 11:31 AM
lacedemen's Avatar
Think it could be the water pump
Old 05-07-2009, 11:43 AM
Brown Water
Livin_Legend's Avatar
Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend
Default Re: Smoke coming from under the intake manifold????
Originally Posted by lacedemen
Ok I was driving an my car sarted to over heat today I pulled over an looked under the hood an seen that there was some smoke coming from under the intake manifold so I cheacked under it an there was a little bit of air pressure also that is blowing the smoke out. So can someone tell me what this might be, the water level was fine
?? This post doesn't make any sense about the air pressure under the mani.
Livin_Legend is offline
Old 05-07-2009, 11:45 AM
B Nice
STi_FTMFW's Avatar
What does it smell like? Antifreeze or oil (or something else)?
STi_FTMFW is offline
Old 05-07-2009, 11:49 AM
Slammedxpert
SortaFlush's Avatar
Positive Crankcase hose came off/blew off?
SortaFlush is offline
Old 05-07-2009, 12:03 PM
lacedemen's Avatar
ok it was blowing a little smoke where ever the smoke was coming from
Old 05-07-2009, 12:05 PM
lacedemen's Avatar
alright that sounds like something that might have happened, where is this crank case hose located, would it also make it over heat
Old 05-07-2009, 12:07 PM
lacedemen's Avatar
im not sure really ill cheak
Quick Reply: Smoke for under intake manifold????
