Spark Plugs and my RX 7
management
SPARKLEmotion
Re: Spark Plugs and my RX 7
You have to take into account that the flash brings out the white. Looks like a tiny bit of oil buildup, but it's a Wankel-dankel, burning oil is it's religion from birth.
starfox: I'm almost sure it's the gap, but I'm hanging in to see if that is for sure. A larger gap NORMALLY makes a conventional engine idle smoother (.042-.048) and sacrifice spark efficiency up top. The same applies with the rotaRRRRRRRRRy, but that .056 sounds WAY to fat. Tat motor normally likes a lower gap (.030-.035) especially the older they get. The guys running more boost normally drop a little lower then that (.020-.027, depending on their setup).
NotAcOp:)
It was actually adjustments I needed to do to the TPS and Idle screw. Going to fix some timing issues once I get this thing i need.
NotAcOp:)
Well we figured out an even bigger problem... This is prob why I cannot pass emmissions. The o2 sensor is only hooked up to the wideband and not the ecu...... facepalm. Going to trouble shoot it on friday and check the solenoids also. Hope this all works out. I will keep yall posted
NotAcOp:)
LOL hey Nashatch nice neg rep ummm unless that wasnt you... but I just bought the car at the end of january... I am doing up keep now ololol ol
"Thread: Spark Plugs and my RX 7
fucking idiot, try doing some Up keep on your car-Nasthatch"
NotAcOp:)
Find out the verdict tomorrow. It appears my entire day opened up so I will be there at 930am ... once we make sure everything works I am going to get it emmissioned again. Hopefully my car will run better. Here is a clip I took at Tacobell..... sounds bad.
http://www.youtube.com/watch?v=AVAOkSVBAV4
NotAcOp:)
LOL i know what you mean its hitting me hard tonight lol.... I have to take off that after market ...cluster cover thingy.... its messin with all my stuff exp my gas... i will sit at full for 150 miles then by 200 empty
