SPUTTERING HELP!!!
Old 02-22-2012, 02:31 PM
dseayman's Avatar
dseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these parts
Default Re: SPUTTERING HELP!!!
im tryin too get the pics up but its not letting me
dseayman is offline
Old 02-22-2012, 02:37 PM
Previously Odyssey
Odysseus Prime's Avatar
Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime
What's not letting you?
Odysseus Prime is offline
Old 02-22-2012, 02:40 PM
dseayman's Avatar
with the upload pics i put an video up too
dseayman is offline
Old 02-22-2012, 02:42 PM
Previously Odyssey
I saw the video on youtube. Where are you trying to upload the pics to? That's what I was asking.
Old 02-22-2012, 02:44 PM
dseayman's Avatar
oh okay in i just found it is too big any other sites i can upload them too
dseayman is offline
Old 02-22-2012, 02:48 PM
dseayman's Avatar
dseayman is offline
Old 02-22-2012, 02:49 PM
dseayman's Avatar
dseayman is offline
Old 02-22-2012, 02:54 PM
Previously Odyssey
I was about to say too big a file? photobucket free has up to 5 MB each or 2048 x 1536 resolution.
But wow at how that looks.
While you have the ignition coil out, you can check its' primary and secondary winding resistances. Can not remember what what the specs are. Would have to find it in the FSM.
And the 2 wires that bolt with those little screws at the bottom of the ignition coil, is that area really rusted? If so, That could be a big problem.
Old 02-22-2012, 02:59 PM
dseayman's Avatar
all of its pretty rusty dude nd ima try too clean it nd put new screws in
dseayman is offline
Old 02-22-2012, 03:11 PM
Previously Odyssey
I believe the Y7 has a TEC coil (Mine does) so look at that one. Simple test to check. Just do it inside at room temperature.
Just make sure your DMM is set to resistance-OHMS and is in the right range for what you are testing (.63 ohms-----or 19k ohms) unless you have one with an auto−range feature and this will be done for you.
Quick Reply: SPUTTERING HELP!!!
