SPUTTERING HELP!!!
Old 02-22-2012, 03:43 PM
  #21
RandomTask's Avatar
Default Re: SPUTTERING HELP!!!
Edit: Did you check your spark plugs?
RandomTask is offline
Old 02-22-2012, 04:17 PM
  #22
eghatch's Avatar
eghatch eghatch eghatch eghatch eghatch eghatch eghatch eghatch eghatch eghatch eghatch
check o2 sensor sounds like what my old car was doing unpluged the o2 sen. and it ran fine.
gl~
eghatch is offline
Old 02-22-2012, 04:18 PM
  #23
dseayman's Avatar
dseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these parts
yeah i gap them with spec there good
dseayman is offline
Old 02-22-2012, 04:22 PM
  #24
WEEEEEEEEEEE
TATTRAT's Avatar
Bad gas.
TATTRAT is offline
Old 02-23-2012, 08:49 AM
  #25
dseayman's Avatar
naw ill just filled up with BP gas
Originally Posted by TATTRAT
Bad gas.
dseayman is offline
Old 02-23-2012, 01:51 PM
  #26
White Devil's Avatar
That motor is hideously rusty. And it almost sounds like you ran a gallon of water through it, or possibly flooded something.
White Devil is offline
Old 02-23-2012, 06:48 PM
  #27
Previously Odyssey
Odysseus Prime's Avatar
Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime
Did you check the resistance on the coil windings like I said or even clean off the rust on the contacts? Takes like 10 seconds to test with a DMM.
Odysseus Prime is offline
Old 02-27-2012, 07:23 AM
  #28
Standartenführer
euthorus's Avatar
euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus
maybe a dumb question - but have you checked the voltages coming out of your battery/alternator ?
euthorus is offline
Old 02-28-2012, 11:24 AM
  #29
dseayman's Avatar
yup i did dat in still no change its the dizzy
dseayman is offline
Old 03-06-2012, 06:35 PM
  #30
dseayman's Avatar
I GOT ANOTHER DIZZY!! im tryin 2morrow.. but is it possible dat o2 went bad
dseayman is offline
Quick Reply: SPUTTERING HELP!!!
