sr20det sputtering under raised boost level
Re: sr20det sputtering under raised boost level
for plugs run the ngk bkr7e. they are one step colder than the stock bkr6e.
check your a/f. you're too rich. i bet it hiccups like crazy till it get full boost towards the upper rpm range huh.
<3's Photography
I'm running the NGK Iridiums available at www.splparts.com. It's found at "engine" then hit "other engine parts." I gapped them to about .030 and I don't have any upper RPM problems. NGK BKR7E's are practically the same but they're copper. Copper or Iridium? You choose.
WIKAP WIKAP PLBTTTTT
I run BKR7E gapped to 0.028. Copper is fine, just change often. I have several laying around if you need some plugs in a hurry. I'm just down the street from you.
So, you have the bigger fuel filter and pump. If new plugs don't fix the problem, you may be running out of injector. It's rare to see it on a t25 SR but, the MAF is only good for about 260whp and you may be hitting that limit with the Mine's ECU.
<3's Photography
youre getting some misinformation in this thread.
my suggestions from experience.
change your plugs gapped to .035 with models listed above whatever ngk 7's are. bkr7e or some shit. we keep those in deep stock here at the shop.
its a fuel pump that is either failing, installed without a filter and clogged or a clogged fuel filter up front. Unless a "larger" fuel filter is the same price as a drop in S chassis filter i wouldnt do it. Ive run many a 300rwhp SR20 setups with stock fuel filters.
I personally think its the pump. I've had several walbro's fail on me. call me at the shop if you need further diagnosis or bring it by the shop for a simple checkup.
check your closed throttle tps voltage and ensure its withing FSM specs. not that it has anything to do with your current issue, it helps driveability as well as the larger gapped plugs. Theres no reason a stock coilpacked SR cant fire off a combustion process in a setup under 300 hp.
master debater
advance wont have the plugs in the heat range you need.
master debater
Actually Advance does. I bought mine there, well atleast the one here in charlottesville does.
