sr20det sputtering under raised boost level
#21
Re: sr20det sputtering under raised boost level
Originally Posted by Greaser
advance wont have the plugs in the heat range you need.
They might not have em in stock, but u give em a part number, ull have em the next day.
#22
midnight motorsports
Blackout... i live two blocks away and you never called me. WTF? I have the plugs you need, you just never asked. You also never told me you were having problems.
Part number is BKR711E
Bap-Geonhas em..10.60 shipped
#23
Originally Posted by blackout
just wondering if anyone else has run into this, or any suggestions for a potential quick fix. here's the situation- runs perfectly fine at 10 lbs boost pressure; no hesitation, sputtering, nothing. but once i raise the boost to 14.5 lbs, it sputters. nothing really obnoxious, but i know it's not supposed to run like that. i also smell fuel real strong... not like the rich smell i've almost gotten used to, this smell is like pure gasoline. i haven't changed the plugs since i got the car in august, and it could probably use a new fuel filter as well, but i'm just sort of curious as to why it doesn't act up until i raise the boost. btw this is a very basic setup, all stock save for exhaust, fmic, and an aftermarket mine's vx-rom tuned ecu. my boost controller is a greddy profec b, if that helps any.
you need a bigger feul pump. My friend Jr has an SR20det in his S13 and as we started to play with the boost it would not want to start like ti was supposed to and sputer a little....get a bigger feul pump and a new fuel filter and you will see a MARKED improvement on the idle, cruising, acceleration, and just flat out fastness...Before he put his pump on, i could pull on him like no bodies business, but then her got a better pump and a new filter and raised the boost like 2-3 psi and stayed at my door...
#24
master debater
#25
Originally Posted by Moriar
if its the 100lph, then its a stock replacement, u want the 255lph.
I reccomend changing fuel filter to the 300zx twin turbo fuel filter, and plugs.
^^^ +1 more boost more fuel... easy fix..... weeeee you in uhm uh.... *looking around* A bonkers action figure dressed as a cop.... lol..
#26
255LPH is perfect.No need to go bigger.
#27
Boner Jams
check spark plugs, fuel filter, fuel pump, maf grounds, engine grounds
#28
Both of you guys can start your own thread. This one is almost exactly 4 YEARS OLD!
