SRT-4 guys, help. AGP wastegate actuator.
#21
DEY SEE ME TROLLIN
![DickButt](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![DickButt](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
![Sad](https://www.vadriven.com/forums/images/smilies/frown.gif)
#23
Slappin Curtis
![bluesrt2004](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![bluesrt2004](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Although im not doubting anyones responses,when i dyno'd mine on 18psi with stock injectors,stage 0 pcm,and open Dp,my A/Fs were still way rich.Factory Tunes are setup to send more fuel,just to ensure that it doesnt lean out and blow up for warranty reasons.The TD-04 looses effeciancy at 23-24 psi.I run 22 psi on mine everyday.I have stage 0 pcm,stage 2 injectors and sensors,open dp,agp adjustable wastegate,and turbo xs boost controller.I did just order my AGP Garrett ballbearing turbo,manifold,and wastegate.Im shooting for 400 by the end of the year....or bust
![Big Grin](https://www.vadriven.com/forums/images/smilies/biggrin.gif)
#24
i <3 my neon
![TheLittleRedSRT is a jewel in the rough](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
I think the stock fuel systems only good for 18psi, tighten the arm 1/2 a turn and it sould get your 3rd gear back to under 18.
#25
ladies love my foam.
Slowest HRC Member
![BAD4DR has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![BAD4DR has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
I was Stage2. Wish I'd had a good FMIC. Was able to run 19/13 (my factory piece was crappy compared to most!) Any higher spike, and I got detonation cause the IAT's were too hot! (Checked with DRB3) I should've just loaded up another stock turbo, just to see!
#29
Although im not doubting anyones responses,when i dyno'd mine on 18psi with stock injectors,stage 0 pcm,and open Dp,my A/Fs were still way rich.Factory Tunes are setup to send more fuel,just to ensure that it doesnt lean out and blow up for warranty reasons.The TD-04 looses effeciancy at 23-24 psi.I run 22 psi on mine everyday.I have stage 0 pcm,stage 2 injectors and sensors,open dp,agp adjustable wastegate,and turbo xs boost controller.I did just order my AGP Garrett ballbearing turbo,manifold,and wastegate.Im shooting for 400 by the end of the year....or bust![Big Grin](https://www.vadriven.com/forums/images/smilies/biggrin.gif)
![Thumbs Up](https://www.vadriven.com/forums/images/smilies/thup.gif)
either that or a straight t3 kit....
350-400 is my goal.
Yeah. Me too!
#30
![Daft Punk](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Daft Punk](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Just to let you know Caleb on our cars its pretty reasonable to do a boost leak test about every two months, our cars are prone to leaks. I do mine every oil change....and if you get with my boy Chris he can show you what items you need from home depot to make one, cheaper than $20 i believe, i made one but left it with the HRC boys on the other side of the water.
