STARTING PROBLEM
Old 09-06-2006, 11:46 AM
Speak&Spell Anyone?
Cpt. Non-Spell's Avatar
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
Default Re: STARTING PROBLEM
Well I would say the starter then. I would bang on it with a hammer and see if it starts that way. You will still need to try to start the car. Banging on the starter won't start the car itself . That is not a fix to the starter that just shows that the starter is going. If you want you can have the starter for 30 buck. I don't need it. pm me and I will give you my number
Cpt. Non-Spell is offline
Old 09-06-2006, 11:47 AM
Speak&Spell Anyone?
Was it cranking before and now it isn't? The battery might have died from trying to start it. Then I wold say the dissy.
Old 09-06-2006, 11:56 AM
Enigma's Avatar
If it won't crank then hit the starter with a wrench a couple of times, if that doesn't work but you still hear the solenoid click over then it might be jammed up. Check the ignition system, my old CRX wouldn't crank over but I could push start it. You would need a dizzy if it turned and there was no spark.
Enigma is offline
Old 09-06-2006, 12:09 PM
psycho jungle cat
Spindrift's Avatar
Ive had a starter just go out of nowehere as well, you also said all you hear is one click, is it coming from where the starter is? Id lean more towards the starter than the distributor, auto zone will test it for free and shouldnt take but a couple minutes to pull so id start there.
Spindrift is offline
Old 09-06-2006, 01:14 PM
GlfDaddy's Avatar
GlfDaddy has disabled reputation
cool thnx..ya i went and hit it with a hammer and then it would start up.
GlfDaddy is offline
Old 09-06-2006, 01:28 PM
Enigma's Avatar
Buy a new/remanufactured starter
http://replacement.car-stuff.com/par...ionType=Manual
Or buy used
http://motors.search.ebay.com/91-civ...ageNameZRC0022
Enigma is offline
Old 09-06-2006, 05:05 PM
Sumospeed #O.G.
SlowLS's Avatar
Actually if it will crank but not turn over, wait 15 minutes and try again. If it starts up, it is your main relay. common problem. I though earlier you said it would not crank.
SlowLS is offline
rockenuptown
02-12-2008 08:11 AM
cleanEK
02-01-2008 03:15 PM
dhanird
07-03-2007 12:00 PM
S14Civic
06-05-2007 08:31 PM
cbucgo
02-10-2005 11:09 AM
Quick Reply: STARTING PROBLEM
