Steering issue. HELP!
Hi
Vehical: 90 integra w/ b18b1
Problem: The car has a hard vibration/rubbing noise when turning left. Its pretty bad when accelerating through turns. When I coast through turns, I dont hear or feel anything. Its real hard to explain but its driving me crazy! The car does have tokico struts and lowering spring, but you cant even notice a drop so I know the wheel isnt rubbing. Any questions, feel free to ask!!
I've replaced: (drivers side only)
LCA
Cv axel
Tie rod (outer)
Lower ball joint
Wheel bearing
I removed and inspected halfshaft and that seemed fine. I dont know what else to do and I'm tired of throwing money at it!! Please help me!!
LCA
Cv axel
Tie rod (outer)
Lower ball joint
Wheel bearing
Re: Steering issue. HELP!
Possibly a differential issue inside the transmission?
Also, are you sure the new axle is good? And everything is installed properly and seated correctly? Do you have the shock fork installed right? As in you didn't mix up the L and R sides when doing the install and the axle is rubbing on it?
It's bad to assume that the wheel isn't rubbing just because you don't have the car lowered. Strut/spring/tire interference problems sometimes happen without lowering at all.
I don't think that is the problem, but I just wanted to bring that up. When you start assuming things, you start overlooking things.
VaDriven Mayhem
