Steps to painting rims
Old 08-24-2004, 07:09 PM
kosher jew
bseriesbenny's Avatar
bseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these partsbseriesbenny is infamous around these parts
Default Steps to painting rims
plain and simple...i looked up search and nothing poped up so if someone that has painted rimes before please go step bye step as to what they did and what they used ...and anything else....thanks
bseriesbenny is offline
Old 08-24-2004, 08:05 PM
RIP Chris Schader
g S x's Avatar
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
Default Re: Steps to painting rims
get some wheel cleaner and clean em, let em dry and then get a red 3M scuff pad from parts store in the body work section and scuff the rims real good. then get a clean towel or somthing and wipe the dust off of the wheels. then paint away. remember, several light coats are better than one thick coat. let it dry in the sun and then clearcoat if you want.
g S x is offline
Old 08-24-2004, 08:57 PM
Die reinste Bösen.
gear's Avatar
get a couple cans of carb cleaner/brake parts cleaner...that shit destroys the clear coat/paint/finish on rims. and pretty much what eclipse said. its not a good idea to do these outside if there is a breeze...dirt will just stick to that paint.
gear is offline
Old 08-25-2004, 04:47 AM
i like prom.
urvtecs2slo's Avatar
i did my previous wheels on my 4 door in 40 degree weather with the wind blowing and they came out excellent. just depends on the painters i guess. are the wheels already on tires?
urvtecs2slo is offline
Old 08-25-2004, 06:28 AM
Gone.
FlipLegend's Avatar
FlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these partsFlipLegend is infamous around these parts
Clean
Scratch
Clean
Dry
Light coat
Dry
coat & dry (repeat steps depending on how many coats you want)
Dry.
FlipLegend is offline
Old 08-25-2004, 08:19 PM
kosher jew
they are on wheels already....so should i just spray aircraft remover shit on first then wipe and shit or??
Old 08-25-2004, 08:38 PM
Speak&Spell Anyone?
Cpt. Non-Spell's Avatar
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
no not air craft remover just brake cleaner or carb cleaner.. make sure you take some masking tape and tape the tire off before you do any painting ofcourse.. don't sand too hard or you will make deep scratches and you will see them like a mother fucker
Cpt. Non-Spell is offline
Old 08-26-2004, 06:42 AM
Die reinste Bösen.
gear's Avatar
yea, use fine grit sandpaper, your trying to just lightly scuff the rims, not gouge them.
gear is offline
Old 08-26-2004, 07:21 AM
200HP/L
Josepi's Avatar
Josepi Josepi Josepi Josepi Josepi Josepi Josepi
Find powdercoater.
Take your wheels there.
Pay.
Get powdercoated wheels.
Profit.
Josepi is offline
Old 08-26-2004, 07:29 AM
Gone.
FlipLegend's Avatar
Use index cars on the wheels so you don't paint the tires.
Quick Reply: Steps to painting rims
