stock LS boost?
#21
Slowest HRC Member
Re: stock LS boost?
http://honda-tech.com/zerothread/1323059
if you want to take a little time there are plenty of stock motor ls-t's in there with boost ranging from anywhere to 5-20 psi of boost.
Large Injectors, and an overkill fuel pump....
#23
Slowest HRC Member
Re: stock LS boost?
With upgraded Injectors and/or upgraded fuel pressure. Upgraded pressure tends to lead to injector failure in a hurry. Read the original question. I said the same. The stock LS bottom end is good to 300 hp. And, it can be done on stock injectors, provided you crank enough pressure. It was quickly pointed out in the following post, that the injectors won't last long that way.
Oh, and a FPR is basically as expensive as a set of injectors, and you really need both to operate the engine properly....But...
#25
Slowest HRC Member
#26
braap braap
Re: stock LS boost?
#29
AWD talon
#30
braap braap
Re: stock LS boost?
Let it be known though...
He not only did that.
We sprayed that motor.
Boosted it.
Then we sprayed and boosted that motor.
Its still holding it down.
2-Steppin'.
Numerous street races.
Numerous highway runs.
Numerous cruises.
The motor won't die. Doesnt even smoke.
Boosted it.
2-Steppin'.
Numerous cruises.
